Texecom R8+ problems!! Not arming
24 Jul 2008
London
Hi All
6 years ago I Installed a Texecom Veritas R8+ 3 texe pir's , 1 Mag, 1PA & LED RKP configured Global Tamper, , System has been fine since install. Last week I wanted changed the part set, Now the system will not arm Full or Part. Starts to arm then I get beeps warning a zone is O/C.
When I now try to do a walk through test the 5 zones are immediately lit. and I get 5 beeps. If I isolate the PA then I get 4 beeps etc.
Walk test Was working before I Changed some of the parameters.
I may have inadvertently changed somthing...
Any Ideas? All zones have the correct assignment
Z1 Hallway = Inhibited entry=T2
Z2 1st floor landing= Guard=T3
Z3 Conservatory=Guard=T3
Z4 Front door Entry/Exit=T6
Z5 PA=Panic=7
Any help would be appreciated
Jodal
Sounds like a wiring issue rather than programming if it is programmed as you say.
