I have 64w panel with wintex connected via a cable. I have a couple of questions
1. I have changed the default engineer and master passwords. The default engineers password (1234) is not recognised by the keypad so it is not apparently still hanging about in the system. However, when I log in to wintex the “UDL Password” has to be set to the default 1234 to enable the connection to be made. I suspect this is possibly causing the problems below.
2. I am making changes to the control panel via wintex using the following process, connect, receive. Then doing some amendments and then send, hang up. Is this correct because all sorts of strange things happen like, language changes, user name but not account disappears, part arm disappears.
Any help would be appreciated. I am trying to sort the problems before asking but I am stumped on this.
I suppose the thing to do is delete the wintex account and log in again, I assume using the new engineer password as the “UDL Password”. Would that be the way forward?
