The generally accepted minimum height difference between the stove and the store is 1 metre - that's what HETAS say you need. Usually measured from centre of stove to centre of store connectionsSo just came across this article and it's pretty close to what I'm doing. So I am getting a solid fuel stove fitted in my house and really want to avoid it being pumped it only 1.5m max from the thermal store it will be heating there's no coil and he store is open vented. I can get around 15cm of rise on the flow to the store over that distance. Is this likely to work and what's the best way to go about it? Should I do a steady rise to the store or come out go verticle 10cm then 5cm rise over the horizontal? Also what safety valves should I be fitting? Swing loaded steam valve? I am a gas engineer but have only ever ripped out gravity systems so my knowledge in this area is lacking.
