The forum's Local tab doesn't seem to have any electricians - in London!
Discussion in 'Electrics UK' started by Vicario, 13 Oct 2021.
  1. opps
    opps
    16 Jun 2006
    5,395
    Thanks Received:
    877
    London
    Country:
    My default state in life is to be ignored so I didn't consider that anyone would question my post.
    • Like Like x 1
  2. Sponsored Links
  3. Vicario
    Vicario
    7 Sep 2008
    442
    Thanks Received:
    8
    Kent
    Country:
    Thanks EFL. That's reassuring.
    I have already got his estimate for a new CU and he will do a separate one for any remedial work needed.
    The electrician who fitted my shower (on a submain) recommended a main cutout upgrade but when the surveyor came from the DNO to start the process he said that a shower up to 9KW would be permissible with my original setup. (He did find a problem with the earth readings so I had that sorted).
    Does an EICR involve disconnecting my power? Mrs Vicario has a couple of Zoom meetings on the day.
  4. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,819
    Thanks Received:
    4,260
    Retired to:
    Country:
    Portugal
    Yes, it should do.
    However, If you are having a new consumer unit, why do you want an EICR?
    Everything should be tested when the CU is replaced and you will be issued an Electrical Installation Certificate followed by a Compliance Certificate from the electrician's registration body which are both part of the job and no extra charge - although, obviously it will be included in the cost.
    Some electricians are adamant that testing (an EICR?) should be done before CU replacement but I could never see how that did not involve an extra day and an extra couple of hundred pounds.
  5. Vicario
    Vicario
    7 Sep 2008
    442
    Thanks Received:
    8
    Kent
    Country:
    My EICR is £220. I did ask him to do one as it's good to know all is well. We did have a kitchen refurb some years ago and the electrics were involved of course.
    Shall I ask him to fit an isolator when he does the CU?
  6. Sponsored Links
  7. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,819
    Thanks Received:
    4,260
    Retired to:
    Country:
    Portugal
    Ok. The extra £220 was my point. You will get an EIC and CC after the new CU.
    Won't he need one before he does it? :whistle:
  8. Vicario
    Vicario
    7 Sep 2008
    442
    Thanks Received:
    8
    Kent
    Country:
    Perhaps the fuse fairy will put in an appearance.
    • Like Like x 3
  9. Risteard
    Risteard
    18 Jun 2010
    2,189
    Thanks Received:
    159
    Derry, Ireland
    Country:
    Ireland
  10. JohnW2
    JohnW2
    28 Jan 2011
    49,209
    Thanks Received:
    3,251
    Buckinghamshire
    Country:
    True, but I think that probably includes Kent.
Loading...
Share This Page
