My first post
Ive got a wonderful Ideal Response 120 that has got a little sick
Basis analysis is that when the hot water is demanded (via tap or CH) the boiler starts up as normal and fires, you get about 5 seconds of gas burning and hot water but then you can here the gas stop burning and the water runs cold. BUT the fan keeps running and the boiler obviously thinks that it is still producing hot water!
Ive had a Corgi guy take a look at it last night and he thinks that its either the: Water pressure switch OR the DHW flow switch that is clogged with lime scale or something as the hot water pressure is less than the cold water pressure when you run the tap.
So in essence the theory is that the pressure is sufficient enough at the start to fire the boiler but as it passes through either of these parts it is being reduced enough for the combustion part of heating the water to stop.
So the Corgi guy now tells me that he will not charge me for the diagnosis but he is not interested in repairing it because the parts are hard to get to on the boiler and it to difficult with this kind of boiler!!!
Both parts come to about £100 inc. VAT. The boiler is about 7 years old I think.
-Do I seek further Corgi help to try and persuade someone to fix it?
-Is this the actual fault or is this guy just guessing?
-Anyone know the sort of labour charge I can expect in London to get these bits replaced?
-Am I better off looking for a new boiler?
Any help would be very gratefully received
