Thermal Store Heating System
31 Mar 2006
Lancashire
Hi
Can you fit a Room stat to a thermal store heating system and if so what do you connect the wiring to.
Its a tower rs stat,
Yes and it very much depends on the store make/model.
Thermostat needs to be wired to control the secondary pump (ch pump)
I think you may be rather missing the point !
A room stat can control taking heat OUT of a store to use it to heat rads etc. ( By controlling the pump! ).
But a fully charged ( hot ) thermal store only contains enough heat for about one hours heating in a typical senario.
Heat stores are primarily used to provide hot water at a greater flow rate than the heat source ( boiler ) could provide.
Tony
All I can say is the r/stat needs to interupt the supply to the heating pump, can't actually tell from pic.
Hi
thanks for the replies, if i connect the stat to the CH pump, it should control the heating due to the pump not pumping if temp reached. surely the cyl stat keeps the store at required temp. probably wrong but hey like to hazard a guess lol
Are you actually going to buy this place?
Hi
That's correct. I have the same system. CH pump controlled by room stat. Thermal store controlled by cyl stat.
Hi
Have looked at the system, now the fun starts.
We have two electrical boxes, one upstairs in cupboard next to the cylinder, CH Pump + HW pump, the other downstairs in the garage next to the boiler. The programmer is in the utility room. The upstairs electrical box is
1 CPC's
2 Blk to HW Pump + Yellow to the Line on the Boiler Pump (via downstairs elec box)
3 Blue to Cyl Stat (sleeved red) + red to Switched Line on Boiler (via downstairs elec box)
4 Blue to CH Pump, Blue to N Boiler feed (via downstairs elec box), + Blue to HW Pump
5 Red to Terminal 3 on Programmer (HW)
6 nothing
7Blk to CH Pump + Blk (sleeved red) to Term 4 on Programmer (CH)
Downstairs Elec Box is
1 CPC
2 Switched Line from boiler connecting to Frost Stat, + Red up to Term 3 upstairs
3 Line Boiler Pump - Red to Line on Programmer, Yellow to Term 2 upstairs
4 Neutral Boiler Feed - 2 x Blues to HW + Ch Pumps upstairs, Blue to Frost Stat
5 Line Boiler Feed = Black to Term 5 upstairs + Red to Frost Stat
How do I go about connecting the Room stat to the system, the Stat is downstairs but it would be difficult to get the wiring upstairs.
Can anyone help my head is full of soft cuddly toys that are broken :)
