I have a 25kW wood pellet boiler that provides DHW and runs the C/H system. The C/H system is open vented i.e. has the traditional F&E tank in the attic. A 400 litre thermal store forms part of the C/H system. IMO the system was badly designed in as much as the 400L. thermal store is a waste of space! I understand the concept of having a TS acting as a buffer tank so that the wood pellet boiler is not constantly cycling on/off; however 400L is far too small for this purpose and one should be looking at 2000L or so. I have neither the space nor the cash for a 2000L TS!
My question is: should I just get rid of the TS altogether and would it really have any detrimental effect on the boiler if I did?
You are probably thinking – why get rid of the TS? Well several reasons:
- I would like to change to a pressurised system so I can get rid of the F&E tank and all the issues that come with having that. The TS cannot be pressurised.
- It costs a small fortune in cleanser and corrosion inhibitor because of the large volume of the TS (it is a direct set-up BTW), which is probably more than the volume of the rest of the system put together.
- I cannot pressure flush the system because of the TS.
- There is currently a problem with air/gas in the C/H system, so hopefully moving to a pressurised system would help with that too (after giving the system a good clean out).
