Thermalite 3.6n
30 Jul 2025
Hi
To meet the thermal u values on my two storey extension, my architect has specified Thermalite shield 3.6n blocks for the internal leaf
My structural engineer has indicated that it is likely I will need a steel ridge beam and he is currently drawing up the designs / plans
To put my mind at rest while I wait for these, is it likely that with padstones fitted above, that 3.6n Thermalites will be adequate?
I’ve bought them already so hoping not wasted my money!
G
The SE is the right one to advise! Nobody else can, it requires calculations and knowledge of the load it's supporting.
They can support - up to 3.6N. So they're not useless. The upside is that, as you know, all that fluffiness gives extra insulation.
This is a danger of split responsibility in design and a cautionary note to not start stuff until the design is complete and BC approved.
BUT perfectly common to put beams onto Celcons. The allowable working bearing stress will be 1N/sqmm which doesn't sound a lot but you get an awful lot of square mm under a padstone.,
To give you a real example: I've just designed a beam for an extension for my own place. It spans 4m carries floor both sides, a wall over it and then 2 tiled roof sections running into a wide box gutter. Padstone will be 700 long. What I have done is avoid any openings below the beam but even if these were required it's merely a case of specifying the right lintel
Hi
G
No dramas.
We have had instances whereby the SE instructed us to build 7n blockwork, local to the point load beam bearings. I think he was being a wee bit over cautious though. It wasn't a big deal.
Alright smudger!
I make the lads to fill the joints. Always have done. I'd rather have a full joint.
