That diagram relates to both 2-port and 3-port valves.I assume that's a 2-port valve ...
Yep, there is an additional 'auxiliary switch' (pair of contacts) for switching boiler+pump(s) etc. I presume that the contacts of that auxiliary switch only close when the valve is fully open (i.e. at the same time as the two 'shown' switches operate).... so am I right thinking it has an additional limit switch, not shown, to start the pump and boiler only when the valve is fully open? To avoid risk of them starting when dead-headed if the valve should fail to open.
Kind Regards, John
