Hi Guys,
Looking at my current system, there are no thermostat controls other than the 0 to 4 dial on the front of my Baxi bermuda
View media item 37867
So other than the programmer turning various parts off at set times, there isn't anything to regulate the temperature, we quite often find ourselves with scorching hot water and a "too hot" upstairs.
Turning the boiler down to 2 hasn't solved it so i'm looking into thermostats.
I've looked at the installation instructions for my programmer (horstmann 425 Tiara) and looks relatively straight forward to add the controls.
Planning on adding a cylinder stat and a room stat at the same time on the upstairs landing, with the stat on a wall away from the airing cupboard I presume? (airing cupboard on landing next to bathroom)
Wiring wise, I'm comfortable doing the work (have done keypad door controls with the gibberish they supply)
and the install looks to be
1) cylinder stat to interupt boiler On unless called by room stat
2) room stat to interupt pump ON
are there any pitfalls to watch for?
The programmer can be setup to supply mains AC to the stats.
Cheers
Matt
Cheers
Matt
