thickness of silicone
22 Jul 2017
Should silicone between top of the shower tray and base of tiles be a thin bead or is more (thicker bead ) better?
A properly applied, thin bead is no more or less prone to leakage than a thick bead (and looks a damn sight better).
Aslong as you are filling the gap any excess on the outside is just waste.
Thanks Adam. A thick bead didn't help seal , I'm hopeful on the thin bead, as u say looks a lot better.
If a small amount/drops of water get into the sealant before it cures does it render it useless even though it may look ok?
I would leave for a clear 24 hours before getting any water on it i.e using the shower.
Water under it can prevent adhesion but water cannot get ‘IN’ to it.
