Thicky question on rigid insulation and brick ties
26 Feb 2005
Gwynedd
Putting rigid insulation on inner skin of block wall. How to fit it when there's brick ties sticking out? Inner is thermalite.
Do I just push the boards so the ties poke through, or somehow fit them after?
As I said, undoubtedly a thicky question.
I thought the boards were sized to fit exactly at the intervals as the wall ties, and then you clip the little plastic disk on the tie to hold them in place?
Our builder just used the big ones and cut out holes and taped over. The smaller ones are more costly per m3, although very useful as loft insulation due to going through the hatch easily
There is I thing another difference in the boards
The "big" boards tend to have square edges.
Some of the "specialist" cavity "batts" have shaped edges, that if installed correctly tend to allow moisture to be trickled away from the inner leaf
Ken
