Following on from my soft red brick post, when "Bill and Ben" the cowboy men, built the bathroom extension on the back of my house they only managed to get that floor about 40 mm higher than the original kitchen floor on the same house level. I expect they built the extension on the back of the house before knocking through the new doorway and managed to get the new floor level totally wrong. It wasn't until I bought floor tiles to go right the way through that I found this out, I put my 6ft level on the floor and thought it must be broken, unfortunately the level worked just fine.
They built the old WC and lean to store into the extension then cocked it up as they went along. Between the bathroom wall and the kitchen wall the floor falls over 1" in just a meter, I've remedied this will deep fill self levelling mix, but now need to get the kitchen floor up level with the rest of the house, so basically I need a screed that is only about 32 mm where it joins the lobby, to about 45 mm at the far end of the kitchen, floor size works out to an equivalent 2.4 m x 2.4 m .
What's the best I can do with it, I've read about putting down a neat cement/pva primer/slurry down on the floor to hold it down, I've got fibre strands to keep it together when its down, I've also got some Ardex to get it dry quickly as there's 4 of us living in the house with the bathroom at the end of the kitchen downstairs.
Any advice, mix ratios etc would be very handy , basically the room will be 8ft square with kitchen units fixed down both sides so the whole screed will basically be held down and not floating, the 45mm depth I'm not too concerned with, its the 32mm depth in the kitchen/lobby doorway that worries me, It will be floor tiled right over but I don't want all the tiles breaking at this point or the grout joints keep cracking, the best I might possibly be able to do is to gun up a bit of the floor at this point to make it deeper if need be. Going to be well expensive if I have to level compound the whole of the floor.
Open to all suggestions possible, please
