thin gaps in laminate flooring
25 Feb 2006
London
can anyone tell me how to fill the gaps between laminate flooring the gap is only 2-3 mm.
thank you. I tried pushing the flooring together but that does not work
heeelllooo bharati
is it klick type!!!!
is it glued!!!!!!
what colour is it!!!!!
are you shure its stable if its likely to move more you may get further problems
first of all i would want to know why click type floooring has opend up!!
if its just a mistake and it was open when laid
then woodfiller either neutral or pine should do the job and be virtualy invisible on beech ;)
if your assembling flooring make shure your not catching the underlay in the groove
also check their is no crud in the groove
i hope you have a nice expansion gap all round :LOL: ;)
thanks but i have tried wood filler.
the gap is too narrow to fill it with wood filler and it goes all on the side and nor in the gap
mmm you use your finger
its the one part ready mixed very smooth type and should be virtualy imposible to notice
is the floor now stable and not mooving if its not stable may cause problems
how exactly did the wood filler fail to work then
1.it happened when the floor was laid
2. the wood filler was not smooth
3. the floor is not moving further
the filler should be only a few shades away from the colour off the floor
then it will fade in
what exactly was this wood filler called :cry:
bharati said:
do not know the name of wood filler, perhaps you could recommed one
ok the stuff i use is ronseal multi purpouse wood filler
and on the lable it says neutral/pine/ light oak!!!!!
i would describe it as virgin pine :LOL: :LOL: ;)
its about £8 for 930g tub
i get mines from expensive home base :rolleyes:
click-systems (specially the thin ones on Melamine Lamianted) can open up when you make a sharp turn on the boards (like at the bottom of the stairs in a hallway, stepping of the last thread and turning around on the ball of your foot, hope you get the idea).
