Thistle Uni-finish
5 Mar 2017
Hi
Has anyone used the new(ish) plaster Thistle Uni-finish? It looks great, same as multi but no need to prep the surface wether its high or low suction.... Used it for the first time the other day going over an existing painted ceiling and it was a bit of a nightmare, first coat pulled really quick then I was chasing it for the rest of the set....id even put a really dilute water/sbr coat on the day before just in case. Anyone else used this, wouldn't mind some opinions on it as if it works the way it says it does, sounds to good to write off after one bad experience. Also, anyone know a good reliable stockist of betokontact?
19 Dec 2009
Hampshire
I remember when this stuff first come out everyone up and down the country including myself swore blind they was putting this stuff in regular bags of multi for us unsuspecting spreads to test I had loads of bags that would go off quick and I would get skim stuck to my trowel after phoning them they offered to replace the bags saying the rumour is untrue and if needed they would have come out on site, if it was that stuff it was awful goes off really quick as I understand it has pva already in the mix awful stuff regular skim for me they can shove that tbh if I could get a regular supplier of knauf skim I would use that it's lovely stuff
5 Mar 2017
Yeah, it did have the smell of pva about it. Shame, if it was a better product it would be great. Whats Knauf skim?
19 Dec 2009
Hampshire
http://www.knauf.co.uk/product-range-overview/plasters/knauf-mpfinish you get 18m2 a bag nearly twice as much as multi it takes longer to go off so hits can be bigger can be machine or hand applied I was converted when on a large job Southampton football club training ground the whole job was knauff if you Go to my profile you will see a big lid I done with it, I tried to get a supplier but minimum of 60 bags order at a time so shame not viable but lovely gear
5 Mar 2017
Some good products out there that are hard to track down....funny old world eh! Thanks for the replies anyway, looks like il be sticking with multi then
