- Joined
- 11 Jan 2004
- Messages
- 47,182
- Reaction score
- 4,134
- Country
Hi guys
Wonder if you could shed any light on this issue?
I have a customer with three 5' flu's in the garage. They are all elderly Thorn fittings with slickstart modules rather than starters and they are all fitted with 58W tubes.
The problem is that the tubes do not fire up properly. On initial switch on,one end of the tube will glow, but no more. If you fiddle with the switch and turn the supply on and off several times in quick succession, the will fire up as normal. Also, the tube ends are running extremely hot.
I have noticed the choke is labelled as 80W. Is there a possibility that the new tubes (having a lower wattage) in conjunction with the slickstart are not compatible, or is it just a case of dodgy lamps?
I have asked the customer to buy a new one to try as all the tubes at the property have discoloured ends. Can't believe all three fittings are dodgy.
Voltages coming in to the fittings are all within the expected range.
Can anybody help me please?
