Some back boxes have holes in the back behind the screw connector, but if your's hasn't drill one with a suitable size drill. Get a long machine screw (50mm should be enough if you've a 25mm back box) and then the screw will bite into your new screwhole. Probably a good idea to turn off the power while you've got the socket open and the wires exposed when you've got a drill in there ....
