Three phase and neutral supply
Makes my mind boggle a bit.
any guidance appreciated
In a three phase system, the return path is the phase difference?
In a three phase and neutral the return path is the phase difference, and the neutral is there if you need a single phase load?
Any current in the neutral on a three phase and neutral is an imbalance between the phases?
So if I put a clamp on the neutral on a 3P and N. Any current on the neutral would show an imbalanced load?
But what is an imbalance load, each phase must have different demands on it depending on what is being used.
few scenarios..
If i had three kitchens, each on a phase, say 100A supply each
1. Two kitchens in use, and drawing 60 A
2. Three kitchen in use and drawing 60A each
3. One kitchen drawing 105A
4. kitchen 1, 50A kitchen 2, 90A Kitchen 3, 10A
What current would be expected on the neutral with these situations
Many thanks
few scenarios..
Many thanks
