Hi, hope someone can help, my central heating will only work if I move the three port valve arm myself then heating is fine and the boiler fires up, I can turn off by the room thermostat and on again and do the same with the programmer but once off for a while the arm on the port valve returns and will not work again to fire up the boiler, by the way the hot water is fine, I have also changed the synchron motor but still no joy and rewired the central heating, I'm being told it could be the thermostat in the boiler (Ideal icos HE28) is this true or should I just pack my bags and move out.
