Three red wires going into ceiling light fitting, no black!
28 Jan 2011
Buckinghamshire
While what you say is strictly speaking true using "Line" for the wires that are 230 V above Earth potential is confusing for the average DIY reader. Like wise calling the Neutral wire Live is also confusing for the average DIY reader.
Agreed, and this may be a situation in which abbreviations are to some extent our friend. Whenever it seems possible, appropriate and likely to be understood, I try to use "L" (or "switched L" or "permanent L"), in an attempt not to confuse DIYers etc. but, at the same time, to not feed those clever clogs who are prone to jump in with comments about 'strictly correct terminology' :)
In fact, I'm not really sure what the 'strict definition of "Live" really is. BS7671 says:
Live conductor (see Live part).
Live part. A conductor or conductive part intended to be energized in normal use, including a neutral conductor but, by convention, not a PEN conductor.
It doesn't define ';energize(d)', so I'm left with having to assume that it refers to any conductor or any 'part' which is not 'intended to be' at earth potential - but that's just a guess! It's also a little odd (confusing?) that, in a TN-C-S installation, the conductor providing the 'return path' back to the transformer is called a 'Live conductor' within the installation, but then ceases to be a 'Live conductor' once it is upstream of the cutout!
Kind Regards, John
18 Jun 2010
Derry, Ireland
Ireland
Was it not Winnie the Pooh who insisted that correct terminology was critical just a few posts back?
Therefore I stand by my point.
28 Mar 2004
And lets not forget that elsewhere in BS7671 it says that single pole isolation is acceptable on TN installations.
11 Jan 2010
London
No one called Winnie the Pooh on this or any other thread I can find. Perhaps you are confusing with another forum.
18 Jun 2010
Derry, Ireland
Ireland
If I was confusing with other forums it would be George "Winnie the Pooh" Cooke, silly boy...
On a completely unrelated note would you like to impart your views on the compatibility of stranded conductors with Wago type connectors?
28 Jan 2011
Buckinghamshire
Certainly. First perhaps you should explain your view.
It's not 'my view', it's the view of BS7671.
I presume that you are talking about 462.1.101 which does, indeed, require that the whole-installation 'Main Switch' ('close to the origin of the installation') in a domestic installation "interrupts both live conductors of a single phase supply" [ interestingly, my domestic installation has a 3-phase supply, so that requirement presumably doesn't apply! ]
However, that is just one special instance of isolation which is an exception to the general rule. In terms of any other isolation (e.g. of an individual circuit or item of equipment), 461.2 applies, and that states that (if certain conditions are satisfied) the neutral does not need to be isolated in the case of a TN-S or TN-C-S installation, without any suggestion that this does not apply to domestic installations.
28 Mar 2004
I have created a seperate thread for this to avoid further derailing this one.https://www.diynot.com/diy/threads/wago-type-connectors.592523/
3 Nov 2006
Bedfordshire
The critical need is to get the message / advice / warning across to the person seeking help in a language that (s)he can fully understand.
If achieving this critical need means some deviation from the strictly accurate description to a description that the person understands is necessary then so be it,
