Thresholds between rooms
1 Oct 2009
London
Hi
I'm replacing the floor in my hallway with a solid wood floor and am not sure exactly where to put the T Section threshold in the doorways off the hallway.
Should it go under the door, or either side of the door (eg. hallway side or dining room side)
If under the door, as the T section is wider than the door, should centered so that a little bit of the ramp is visible on either side of the door when the door is closed or no ramp visible on the hallway side?
Cheers
G
should be under the door. When the door is shut you should not be looking at another rooms finish poking through.
Thanks for the reply.
As the threshold is wider than the door, should there be a bit either side of the door when it is closed, or should the excess all be on one side of the door?
Cheers
G
