Only possible if we are friends; I’ve sent you a friend request.I tried to private message you but it looks like I can't.
It’s no longer called Corgi, its Gas Safe & you must get a registered fitter to install, test & certify the gas run; I doubt any registered Gas Safe fitter would dare risk signing off DIY work.Getting a Corgi gas guy to run the gas pipe and then wrapping it in denso before dropping the ballast?
The ducts are formed in the over site ballast using a suitable former (could be greased timber) which is removed once the ballast has set, the pipes are laid in the duct, pressure tested & the duct filled with Vermiculite granules, the screed is then laid over the top. If you are going to use insulated backer boards instead of screed, I would just lay these over the top of the ducts.Ideally I should be putting this part into a break out duct with granular vermiculite. Can I ask how to do this please? Is it difficult?
No, they won’t burst with expansion & contraction, only if the water in them freezes.I guess with the radiator I can do my own solders and then check for any leaks before denso taping it and then also putting it into a break out duct. Will the radiator copper pipes not expand/contract and burst?
Just wrap it around the pipe; 50mm tape will be more manageable on thin copper pipes.Would you use 50 or 100mm denso tape fir the 15mm pipes and is there a technique for applying it? Does one coat do the trick?
A kitchen is a special location &, strictly speaking, he cannot sign off someone else’s work; all he can really do is do a PIR & sign off the results of the test which is not the same as a minor works certificate which you need as regulations go. It does happen but I’m surprised he’s agreed to do that, if he gets found out he runs a risk of being prosecuted, loosing his registration & his livelihood.Lastly, an electrician has cone up with a plan for me to take care of the wiring so I can drop the ballast in. He's going to come back at the end and connect the new kitchen ring into the consumer board and check it/sign it off.
I’m unsure of the regulations regarding running cables in solid floors; unlike walls, they don’t seem to have defined safe zones. I suspect that they should be laid in conduit (or you’ve no chance of ever replacing them) & at least 50mm below the surface for safety. Personally I would follow the more conventional route & run the new cables in the celing & drop down the walls within the defined safe zones;My question is... how do I run these cables? Through the ballast or under the DPM or how?
http://wiki.diyfaq.org.uk/index.php?title=Safe_zones_for_electric_cables
