Oky then "gcol" You ask, "What makes you think that the plaster will fail to adhere, blister and crack?" ANSWER, Plaster that is applied over say non-porous glossy tiles without PVA then the Plaster will not adhere to the surface mentioned, though it will adhere to the grouting areas (i.e. the grouting area will hold the plaster on but it will be prone to blister, crack or fail at the non-porous glossy tiled area).................Then you state, "If you put pva over a tile it won't cover it cause it's not porous - being water based it'll just bead up" MY OPINION, PVA is for sticking to non-porous surfaces also. However the PVA must be applied neat (unthinned) in order to stick to such surface........................Then you state, "It's the same situation when you tile on top of tiles - you don't pva the tiles then." MY OPINION, is that tile adhesive is of an slight flexible body and is of different ingredients as of Plaster is.......................Then you state, "
I thought the idea of using pva was to provide a stable background on porous and/or dusty surfaces with which to work. Using pva will give you a background surface that will, to some extent, slow down the suction of water from the plaster/render. Thus allowing it to "go off" properly. " MY OPNION, I totally agree
.........................Then you state, "With tiles there'll be no suction at all so this surely won't be a problem." MY OPINION, Tile Adhesive is a different product than plaster !..................Also, certain PVA will stick to non-porous materials such as Glass, Oil Based Paints and Ceramic Tiles. Also certain PVA will stick to porous Plaster, Fabrics, Chipboard and Wood. However, certain PVA does have some limitations though as it will not adhere two non-porous surfaces (i.e. water entrapment). And certain PVA should not be overpainted with paints, as this can cause blistering. NB i have used plaster over tiles and oil based paints many times though i apply an neat PVA coat prior to applying plaster. And there still stuck on those surfaces 10 years on.
