Hi all
We recently had a new bath installed. It is surrounded by walls on three sides, and it turned out that one of the walls wasn't square leaving a larger gap. So when it came to tiling, the tiler said it would be best to have a tile trim, the type you put into place before tiling and then tile onto. The bath was siliconed before the tile trim, then the trim was added and then the tiles...
The plumber said he would come back to add more silicone as a final step. But when he came back (he had other work to finish as well) he changed his mind and said the silicone wasn't needed. I asked whether water would get under the trim but he said it wouldn't be a problem.
Just wanted to check in with you guys whether you think he is right, or whether it needs sealing?
Many thanks and hope you've all had a good Christmas.
Cheers
Cheers
