I want to be able to run wall tiles down to the floor (ie no skirting) any help on how to prep gap that is usually left behing the skirting boards. Groundfloor external walls.
Rake out any loose stuff.
Bond the remaining dusty and loose crud with diluted PVA.
Fill the gap with a sand/cement mixture, and leave to go off.
Tile as per normal.
