Tiling noob help needed.
13 Mar 2005
Hi people,
So I'm about to have my first go at tiling, its a small en-suite where the existing floor tiles have some cracks and are some are a bit loose. I'm planning on ripping them up this weekend and removing as much adhesive as possible but it looks like these were laid straight onto the floorboards previously.
Am I right in thinking I would need to use 6mm backerboard for a better stable tiling job and if so do I have to screw them down as I would be in full on panic mode about hitting CH pipes. Would flexible tile adhesive under them be enough? If not can anyone recommend a screw length or type that would work and guarantee I don't hit any pipes!
Thanks in advance.
Hi people,
Thanks in advance.
Just to answer one of your questions, if you use screws which are the right length to only screw into the floorboards, you'll not hit any underfloor pipes.
You should be able to see where the floorboards are fixed down. Just get screws that will only go in half way into the floorboards.
