tiling on previously tiled wall
5 Jan 2011
Derbyshire
i have stripped my en suite and am about to re-tile. My question is can you tile onto old wall adhesive. ON stripping tiles some of the paper coating on plasterboard came away. If i can tile on adhesive do i need to seal plasterboard and with what. cheers :P
You posted the wrong forum; the Tiling forum is the one you want. You must get the tiling surface as flat as possible so need to remove tile adhesive where it is proud. It depends how badly the plasterboard has been damaged, it may need replacing which is usually easier & desirable given that what you most likely have just ordinary wall board. You would not normally seal new PB before tiling but follow the adhesive manufacturer’s instructions. In wet areas, PB should be tanked or it’s unlikely to last too long. If you replace the PB use a waterproof tile backer board rather than more PB.
Take some time out to read the Tiling Forum sticky & archive threads, lots of info & advice in there that may prevent you making expensive mistakes. Too many potential pitfalls to list but have a read & come back with specific questions if you need to.
