Tiling straight onto screed
20 Apr 2011
Suffolk
Hi I’m currently looking to tile my kitchen however as it’s been extended it has 2 different screeds , one very grey and new and one 27 years old and looks more reddish however I’m told both are screed. I want to tile onto both screeds however do I need an acrylic primer to be applied first, or can I just use tile adhesive. A big concern for me as can’t seem to find an answer - thanks
Read the tile adhesive application data sheet online. It will tell you how to prepare surface for adhesive
OP,
Use a cheap SBR primer such as: Everbuild 503 SBR Bond or similar.
Use a powdered thinset adhesive.
Are both screeds at one level? Has the join between the screeds been given special attention?
Thank you
I have some Bostick Cempolay universal primer purchased through Screwfix and hopefully can use that now
The join as in the picture has the new screed overlapping the old screed 2 to 3mm
A professional tiler dropped by late last night and after using a long spirit level told me the surfaces where flat and said he didn’t need self leveller to be used and wasn’t worried by the join as the adhesive would compensate
I wouldnt tile straight over a joint of very old and new screed
you are asking for cracks -Opps above has the correct answer
how long has the new screed been laid, it will need about 75 days to dry if its 65mm thick....not so important with a decoupling mat
Thank you all some excellent guidance
The new screed has been down about 30 days and about 40-50mm deep
The builder told me to consider self level and feather it across the joint
On the old screed I did notice a crack near the outside door which had as it happens cracked the tiles above it
Wonder if there is a very light fibre glass matting that I can apply across the joint and the screed crack too
