Hi;
I am building a small workshop in my garden, project here. The back wall is already in place and is full height against which I have built three block walls four courses high. On these walls I am building a timber frame using 75mm x 45mm timber. The frame will be clad with T&G or fortex TBC.
I have just bought some 100mm Multi Fix screws to fix the wooden frame to the concrete blocks - this will give me 50mm into the block - will this be sufficient (it only needs to hold the wood frame in place with little or no horizontal or vertical movement?
Read more: https://www.diynot.com/diy/threads/...-for-shed-advice-please.487911/#ixzz4rLqy9MgJ
