    Dismiss Notice
Timber size to cover 12 foot width flat roof.
Discussion in 'Roofing and Guttering' started by BML, 1 Sep 2011.
  1. BML
    BML
    12 Aug 2004
    56
    Thanks Received:
    2
    Country:
    I'm helping next door to build a garage with concrete blocks because I was a bricklayer. The garage is going to have a flat roof with a pich and its 12 feet wide. Next door reckons on using 2" X 6" but I think thats a trifle over the top.
    Could someone please sugest what timber size he should go for.
    • Thanks Thanks x 1
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    27,176
    Thanks Received:
    3,400
    West Mids
    Country:
    How is it a flat roof with a pitch? :LOL:
    Anyway, 6x2 is actually under the top and you will need at least 7x2 at 400 c/c otherwise 8x2
  4. noseall
    noseall
    2 Feb 2006
    35,455
    Thanks Received:
    2,233
    Staffordshire
    Country:
    Concur with Woodshaving, my calculator says 7"x 2" is a trifle lean by todays' standards.
  5. BML
    BML
    12 Aug 2004
    56
    Thanks Received:
    2
    Country:
    By flat I mean not with a gable and a ridge but flat with a drop of about 12 inches from one end to the other. I have to say I am suprised at roof timbers of 7". Its only going to carry roofing felt.
  6. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,060
    Country:
    It won't fall down with lesser timbers but it'll get a horrible bow in the middle.
  7. leew2
    leew2
    13 Dec 2008
    190
    Thanks Received:
    17
    Lincolnshire
    Country:
    According to the table here:
    http://www.e-lindsey.gov.uk/NR/rdon.../0/014Flatroofstimbersizesandconstruction.pdf
    you need at least 7x2 inch timbers at 450mm centres.
    Of course your garage will most likely be exempt from building regs so you can use whatever timber size you want but be warned that using undersized timbers could cause the roof to bow and thus cause water to puddle on the roof and increase the chance of it leaking.
    It may only be carrying felt most of the time but don't forget you could end up with a foot of snow on it which would add quite a bit of weight.
  8. ^woody^
    ^woody^
    3 Sep 2006
    27,176
    Thanks Received:
    3,400
    West Mids
    Country:
    No, the beams are made of timber not helium and don't just float there - they will sag under their own weight too
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
