    Dismiss Notice
Timber Stud Stuck In Brickwork!!!
Discussion in 'Wood / Woodwork / Carpentry' started by Eddman, 2 Nov 2017.
  1. Eddman
    Eddman
    3 Sep 2008
    136
    Thanks Received:
    Tyne and Wear
    Country:
    I am re-furbing and there is a timber stud full height with screws into party wall (brick) i cannot get the screws to move even slightly using an impact driver or a combi drill or my own delicate hand with screwdriver - any ideas how to get this shifted?
    thanks in advance Ed
  2. Sponsored Links
  3. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,371
    Thanks Received:
    2,010
    Devon
    Country:
    Angle grind the heads off? Use a crowbar to lever the stud away? Drill the heads off?
  4. Eddman
    Eddman
    3 Sep 2008
    136
    Thanks Received:
    Tyne and Wear
    Country:
    i was thinking of just crowbar forcing it off!!! thanks
    just wondered if there were any tricks of the trade to make it easier...
  5. foxhole
    foxhole
    14 Mar 2006
    15,153
    Thanks Received:
    1,639
    Kent
    Country:
    Cut stud above each screw, then use the leverage of the timber as you lift bottom of each cut section .
    • Like Like x 1
  6. Nigel_Cro
    Nigel_Cro
    5 Feb 2006
    228
    Thanks Received:
    23
    Hampshire
    Country:
    drill the heads off, remove the timber, get mole grips on the screw shaft, simples...
  7. Eddman
    Eddman
    3 Sep 2008
    136
    Thanks Received:
    Tyne and Wear
    Country:
    i ended up using a mixture of multi tool behind the stud to cut off the screw and brute force! it worked in the end, thanks for your suggestions :)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
