P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 9 Dec 2018 #1 Hi, Just a quick question on if my current set up is compatible with the Hive system and if it's a case of a simple wiring swap? Current time switch: Hive Wiring Diagram:
flameport Joined 10 Mar 2007 Messages 13,110 Reaction score 3,558 Location Poole, Dorset Country 9 Dec 2018 #2 The single channel Hive could replace that timer. Whether it is suitable depends on what that timer is connected to, and if there are any other controls such as a thermostat.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 9 Dec 2018 #3 Thanks flameport. The time switch controls an outdoor oil boiler, Gerkros I believe. No thermostat.
flameport Joined 10 Mar 2007 Messages 13,110 Reaction score 3,558 Location Poole, Dorset Country 10 Dec 2018 #4 Oil boiler is ok for use with the Hive. 3 & 4 on the old timer are L & N on the new. 2 on old timer = 1 Common on the Hive 1 on old timer = 3 Heating on.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 10 Dec 2018 #5 Really appreciate that flameport.
ban-all-sheds Joined 27 Aug 2003 Messages 69,773 Reaction score 2,891 Location London Country 11 Dec 2018 #6 Should really be in "Outside UK" - there may be regulatory issues in the RoI of which we are unaware.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 17 Dec 2018 #7 Thanks. I hadn't realised that there was an outside UK section. Perhaps it can be moved if required? Curious to know what the two wires in 1 and 4 here would be linked to? Seems to be two appliance wires in both. Last edited: 17 Dec 2018
ericmark Joined 27 Jan 2008 Messages 27,521 Reaction score 3,326 Location Llanfair Caereinion, Nr Welshpool Country 24 Dec 2018 #8 It does actually say on the box. 3 and 4 are power to the timer. 1 and 2 are the relay contacts. So 3 goes to L Hive 4 goes to N Hive 1 goes to 1 Hive 2 goes to 3 Hive
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 24 Dec 2018 #9 There are currently two live wires to an appliance. I was wondering what these two would be for?
ban-all-sheds Joined 27 Aug 2003 Messages 69,773 Reaction score 2,891 Location London Country 25 Dec 2018 #10 You could find out by looking at what the other ends are connected to.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 25 Dec 2018 #11 You could yes. Well done ban-all-sheds.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 25 Dec 2018 #12 flameport said: 3 & 4 on the old timer are L & N on the new. 2 on old timer = 1 Common on the Hive 1 on old timer = 3 Heating on. Click to expand... ericmark said: 3 goes to L Hive 4 goes to N Hive 1 goes to 1 Hive 2 goes to 3 Hive Click to expand...
ericmark Joined 27 Jan 2008 Messages 27,521 Reaction score 3,326 Location Llanfair Caereinion, Nr Welshpool Country 25 Dec 2018 #13 Swapping 1 and 3 makes not diffrence, both are correct.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 25 Dec 2018 #14 Thanks ericmark, appreciated. Hope you're enjoying the holiday period.
P Pat 1010 Joined 9 Dec 2018 Messages 9 Reaction score 0 Country 25 Dec 2018 #15 This is what we're looking at so?
