I had a building company round last night to provide a estimate/quote for some internal structural works including new cloakroom and fitting a new kitchen, they will project manage the job as well and they have all the trades in house. Nice guy and said all the right things until the amount of time it would take to do the works. I’ve listed the works below (not in very much detail) but he’s said it will take about two months to complete, this seemed a very long time to me, but I may just be naive.
Is two months fair for this amount of work?
I’m now dreading the amount that it’s going to cost, if I’m so out on the length of time it will take, my estimates are probably well under too!
Remove and dispose of old kitchen and flooring throughout area (35sqm)
Remove and dispose of two radiators
Remove French doors and window in external cavity wall (single storey extension), insert rsj to SE spec, make good and replace with bi fold doors (separate company to supply and fit).
Build stud partition wall for new cloakroom, associated electrics and plumbing
Remove internal french doors, central pier and 1.5m of single skin brick dividing wall to create open plan space, insert RSJ to SE spec, make good.
Extend kitchen and provide electrics and plumbing for new layout (plumbing to be moved by two metres, new ring main for electrics and new gas connection for hob)
Plasterboard ceiling in kitchen and backroom and skim – insert 20 downlighters
Skim walls in kitchen and any other areas to make good
Lay new flooring including underfloor heating (carbon film most likely)
Install kitchen and two built in cupboards
I’ve asked for a quote for all the decorating as well, although I will more than likely do this myself.
Regards,
Matt
Regards,
Matt
