What i'm proposing to do is hit one button on a timer, which will turn on a heated towel rail and fan-heater for a pre-set time.
I'm thinking, take a 2.5mm spur from an RCD protected ring to a switched FCU
then into the timer.....
then take two 1.5mm feeds from the load side of the timer to two
one 3A for the rail (600w) and one 13A for a wall fan heater (2Kw)
Q. In theory it will work, but is any of it aloowed under regs ?
Q. Would it be ok to take two feeds out of the timer ?
Q. Should the above un-switched FCU's be switched ?
Q. can either the non-switched or switched FCU's be mounted in the bathroom (zone 3) next to the two appliances ?
Any help or suggestions please....
