Hello - I need to replace the timing belt on a 2.0 Peugeot Expert 2017 coming up to 60k miles. I have done belts before but not on this series of engine - my question is regarding the timing of the crankshaft and what tools I need to buy. Crank timing seems to be set by a strategically-shaped pin that fits through a hole in the bellhousing - so I need one of those. Anything else or can it be blagged with drill bits and bolts?
Does the fuel pump need to be set up? I know it is Common Rail but when I did a 2.0 VW CR I had to pin the fuel pump as well.
Very little info about timing belt replacement on the 2016 on 2.0 Dispatch/Expert which is surprising given how many are on the road. It's a preventative maintenance exercise to replace the fragile water pump.
Can only find details of the 1.6 online and that looks different.
Thanks for reading
Thanks for reading
