Tin baths
11 Dec 2007
Essex
I am just about to install a tin bath, and unlike the plastic types of bath it does not have wooden strips running around it to mount the L shaped brackets (the brackets are not included too). What do people do with these baths to connect/tie them to the wall to stop movement between the bath and the wall/s.
Jeremy
tin baths or galvanized will rust if drilled or scratched.
get a wood , plastic or metal mount and use the glue in a tube they use to join brick tops to cement walls, after it drys it will hold firmly.
do you really mean tin?
or do you mean a portable galvanised bath?
or you you mean a pressed steel one?
A photo would be illuminating.
