In hard bricks, probably about none.I wonder how much chasing could be done with one of those vibrating multi-tools?
In soft bricks and aircrete, yes, but how deep would it go?
And how long would it take?
No, I said pressurise the house - which means airflow would be from the house, through the room I'm working in, and out the window. With the fan I've got, wouldn't worry about the house being leaky - it shifts plenty of airIf you pressurise the room you're woking in higher than an adjacent room, you'll force the dust into that adjacent room.Turning things around, I might try putting it at the back to door pressurise the whole house - it'll do the same job as de-pressurising the room I'm working in.
Coool
I had thought of that, but with bricks this hard I figured it would finish off an expensive blade in no time.I wonder how much chasing could be done with one of those vibrating multi-tools?
<quick search><adopt Yorkshire accent>HOW MUCH![]()
I'll be interested to hear the results - I've got a Bosch GOP. Never thought to look to see if you can get blades that will do brick.I'll try to cut a couple of bricks tonight. I have some spare blades....
http://www.tvtoolhire.co.uk/product/arbortech-allsaw/[/QUOTE]
Slight geographic issue with that outlet
Someone with a branch in my area : http://www.hss.com/g/3126/Allsaw-Multi-Purpose-Saw.html
Nigh on £70 + VAT for the first day. Since I'm not doing the whole house at once it'll soon add up.
Only used one once - many years ago when someone let me use their Split to chase out in some rendering that I couldn't even mark by handFor brittle bricks I find the best thing is a scutch chisel and hammer.
The toothed blade chips away nicely at the brick and does not tend to crack them so much.(it had been a cattle shed and was being converted to offices)
I guess this plus these. Are they a standard size or do the combs have to be the same manufacturer as the holder ?
I don't have a guard on any of my chisels - you soon learn where to aim the hammer !Only thing I find with scutch chisels is they never come with guards, so you can give your knuckles a few bangs in the process.
