Hi guys and gals,
newbie here ...Would like some advice on right size wood for a timber frame that will be holding 7ft mdf doors.
The doors will be 7ft in height and 2ft wide ...Altogether there will be 5 doors.
The frame will be attached to the walls to make it more sturdy.I am using mdf 18mm for the doors ..Was thinking about using 4-5 hinges on each door..Will the hinges fix ok on the 18mm mdf (not sure yet which hinges to use) also will the mdf warp or will it be ok ?
Seen some stud at wickes which is 38x63mmx2.4 would this be ok to use with the mdf ? Was thinking of adding some Decorative mould to the front of the mdf. Using mdf for the doors as i am on a budget so that's ok with me lol.
I have a few tools so thats not a problem, but i am not very experienced with wood work but want to have ago.
Thanks for your time,could do with a little help
