laying a close-coupled toilet,the floorboards are not level,out by around 3-4mm,any tips on how to level the pan so the cistern sits level,
or would you just screw the cistern to the wall so it sits level,or would that cause problems with water leaking because the cistern wont be sat fully on the rubber dohnut,
i did a search,took me ages
,all i found was one bit of advice was to use cable ties as spacers then silicone to help hold its postion
thanks
thanks
