TMV Fault
13 Feb 2006
Hampshire
I have a bath/shower mixer (one from ultra-group). It has two taps on it one feeding the shower, the other for the bath - plus a separate temperature control. The problem I have is that the unit only provides really low flow on the hot water - it works fine with the cold. I initially thought it was a air blockage as it would start okay when cold and then slow down as it warmed up. There is loads of pressure (4 Bar), and the hot & cold feeds are balanced. I now think it might be the actual TMV2 valve that is faulty. Has anyone experience a similar fault where a TMV mixer cannot deliver hot water?
Are there filters on the TMV inlets? Could be that the hot side is blocked.
I contacted Ultra and they sent out an engineer. Apparently the mixer mechanism was broken - replaced for free under 10 year warranty - excellent service :D
