I've just dry lined the downstairs loo, dot and dab, can anyone tell me will I need to have the wall skimmed before tilling or can I simply tile straight onto the plasterboard.
No need to skim the bits your going to tile & it will reduce the weight of tiles you can use if that's an issue. If only 1/2 tiling & wan't the rest plastered, get your spread to "waste" the plaster into the area around 50mm below the tile line, then tile.[/quote]
