Garden room - 2.8m x 3.2m
Walls and ceiling lined with tapered edge plasterboard, sealed with PVA, and joints taped with scrim.
The walls only have tapered edges meeting tapered edges. The ceiling has a couple of joins with square edges.
I've had a look at loads of videos on how to finish the walls.
1) Just skim the joins. (The Aussie method?)
2) Use a paint roller to apply a skim coat and then use a trowel to smooth. (The US method?)
3) Use a hawk and trowel to skim everything. (The UK method?)
Opt 1 seems the easiest and least work
Opt 3 looks the hardest and most work
In terms if getting a reasonably smooth, paintable finish (where hopefully the joins don't show) what are the pros and cons for a novice "plasterer", and any tips please?
