I have a Wbosch system boiler with an indirect vented cylinder. I'm considering installing an unvented cylinder (santon/albion) to improve my DHW pressure. The problem I have is that my cold mains is entirely piped in 15mm copper (to replace this with 22mm would be too costly/disruptive). Severn Trent have advised that the cold water pressure should be a minimum of 1.5 bar. I have measured the flow rate at about 12 litres/minute. It would seem that my cold water pressure/flow are not sufficient for an unvented cylinder- do pple agree?
As an alternative I have considered fitting a pump to the DHW pipe (22mm) just as it exits the current vented cylinder (perhaps a stuart turner single 2.0 bar monsoon).
What would YOU choose?!
