Toilet cistern not filling
18 Nov 2026
My toilet cistern is not filling, just keeps running through into toilet, I've stuck a pen in it for now as the continuos noise of running water is driving me nuts!
Advice very welcome! I've attached photo.
Thank you
Lift float with your hand (on the left of picture) dose water turn off? If not then rubber needs replacing.
Rubber has grits or worn so not shutting off causing water to rise spilling over the syphon (flush) Toilets overflow into themselves now through syphon which is why it keeps running.
If when you lift float water shuts off then check overflow hight on syphon and check float height cutoff
Water does turn off when I lift float.
"If when you lift float water shuts off then check overflow hight on syphon and check float height cutoff"
That all Greek to me, don't understand, help!
I've closed two values, I'll attached photo assuming that is the value? Two closed but one is still open I think
The flush valve should be removable, try gently twisting it anti-clockwise to remove. Check the bayonet cradle for debris or the washer for being perished.
