hi all. unpacked new toilet n cistern and all fixing gear today. had loads of problems.instructions said. insert siphon n rubber washer thru bottom of cistern. attach plate, big plastic nut and big rubber washer put square ended bolts thru plate thru toilet pan and tighten up. so far so good. can someone tell me why there are two holes thru the bottom of the cistern above the heads of these bolts. theres no plugs or anything in the kit to bung up these holes.
problem 2... on the right hand side underneath there is an inlet hole and on the front right there is a handle hole. thats all the holes there are. there is not enough room for the siphon and the ball....help please
