    Dismiss Notice
Toilet Flush Problem - new toilet
Discussion in 'Plumbing and Central Heating' started by elbitrevnoc, 7 Mar 2019.
  1. elbitrevnoc
    elbitrevnoc
    24 Mar 2009
    18
    Thanks Received:
    Berkshire
    Country:
    We've recently installed a new back to wall pan with concealed cistern in vanity unit and have a problem with the flush. The flush doesn't cover the whole pan, pretty much missing all of it from around 2 o'clock to 7 o'clock if you think of it as a clock face. The cistern is filling to the line and overall water supply is good.
    We've now tried replacing the pan, in case a fault in manufacture was to blame, but found exactly the same issue with the replacement and we're now running out of ideas. Would be very grateful if anyone has some suggestions and/or previous experience of this problem.
    Thanks!
  2. Sponsored Links
  3. Lower
    Lower
    22 Dec 2005
    2,192
    Thanks Received:
    303
    UK
    Country:
    Is the pan level?
  4. elbitrevnoc
    elbitrevnoc
    24 Mar 2009
    18
    Thanks Received:
    Berkshire
    Country:
    Good thought, thanks, but it's bang on. We don't seem to have any blockages and we've also tried getting the cistern a little higher to see if it improves flow, although I would expect it to cover the whole pan even if the flow was weak.
    Really scratching our heads!
  5. just pumps
    just pumps
    24 May 2016
    2,982
    Thanks Received:
    506
    Country:
    Two bad castings from the same company, holes aren`t clear, which make is it or from where did you buy it?
  6. elbitrevnoc
    elbitrevnoc
    24 Mar 2009
    18
    Thanks Received:
    Berkshire
    Country:
    Thanks. A bad casting was the original suspect and so a replacement pan was supplied. I’ve been assured that the replacement was tested before they sent it out, but whilst I’ve no reason to disbelieve them on that front, I can only say that the performance is no better.
    Is it that likely that the manufacturer (Qualitex) might simply have a bad batch? Anyone come across this before?
    I’ve also tried swapping the cistern back to the old one BTW, but I still get the same result. That would surely suggest that it is the pan that’s to blame, but two in a row..?
  7. Sponsored Links
  8. lostinthelight
    lostinthelight
    11 Feb 2016
    3,159
    Thanks Received:
    610
    monmouthshire
    Country:
    Flush pipe too far into toilet?
    • Like Like x 3
  9. elbitrevnoc
    elbitrevnoc
    24 Mar 2009
    18
    Thanks Received:
    Berkshire
    Country:
    Don’t think so, thanks, but it’s something I will double-check. Having refitted it around 10 times now, i’d Hope that I’d not have done so every time, but it’s worth another look. I’ve pretty much tried everything else!
  10. lostinthelight
    lostinthelight
    11 Feb 2016
    3,159
    Thanks Received:
    610
    monmouthshire
    Country:
    Mark the flush pipe against the pan connector then remove the pan, refit connector on pipe to the mark and see how far it protrudes beyond the end of it...the connector its self shouldn't be pushed too far in beyond flush with the back of the pan .
    I have,but not recently seen like a plastic piece inside which I assume is a diverter ?
  11. elbitrevnoc
    elbitrevnoc
    24 Mar 2009
    18
    Thanks Received:
    Berkshire
    Country:
    Thanks again. Will try what you suggest and let you know how I get on, although I won’t get a chance to get back to this until early next week now.
    Yes, the plastic piece is simply a diverter that directs the water to both sides. The original thought was that this was missing, but it is in place.
    Really appreciate your suggestions. Thanks again.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
