I need to replace the flush on a toilet (close coupled). I bought a fluid master dual flush https://www.screwfix.com/p/fluidmas...-2-button-cable-dual-flush-bottom-inlet/58353 which I've used before on other toilets in the house. Albeit its been a small number of years since I last did this.
The existing arrangement has a foam (?) washer that sits on the toilet side, which the outlet locking nut sits on to. That washer is knackered, and may be the source of the leak between the cistern and the toilet that we were having.
This is not included in the fluidmaster flush (and inlet valve) kit. The outlet hole and inlet hole are 2.5" btw.
What do I need to replace the washer ? Also a concern I have is that the diameter of the locking nut on the new flush is smaller than that on the existing arrangement, and also deeper. So not sure how well it will sit on a replacement washer.
Feels like I'm missing something here.
