Hello
I’m having a problem with water leaking from around the base of my bathroom toilet.
I noticed this a while ago (a few months maybe?) but oddly it doesn’t seem to be a regular thing – it will seep for a few days, then it’ll be dry for a week or so, then it’ll start seeping from the base again.
It’s not condensation as the rest of the toilet including the cistern is bone dry.
I did get a plumber to come out to look at it a few weeks ago (typically, by the time I was able to book him it had stopped leaking and had pretty much dried up) and he replaced the seal around the large plastic pipe that runs from the back of the toilet out of the bathroom wall.
Things had been fine since then (about 3 weeks), no leaking whatsoever, and I was just starting to relax and believe that whatever the plumber did had sorted the problem. However this weekend it has started to leak again.
On closer inspection I can see a hairline crack running from where the base of the toilet meets the floor to about 3 inches up the base (at the front). I don’t know if this might be the cause of the seeping (I thought the space behind the base at the front was hollow?) I can only presume the hairline crack has occurred recently as I’ve never noticed it when cleaning the toilet before (not that it’s that visible if you’re not looking properly).
The toilet itself is fairly old (I would say 30+ years) and one of those council house ones with the plastic cistern.
Do I need to replace the toilet or can something be done about this seeming irregular leaking?
Thank you.
Thank you.
