I installed a new close coupled toilet with a 6 litre flush. The waster outlet terminates to the side with a rigid bent pan connector.
The entire 6 litres does flush in to the pan yet when initially testing, it does not take away toilet paper. It’s just spins round in the bowl. There is not blockage and the water level doesn’t need adjusting.
Is this just a case of a poorly designed toilet? Or maybe the bent pan con cause by issues?
Anyone had this before on a toilet where water level is correct and no blockages
