- Joined
- 31 Jul 2021
- Messages
- 11
- Reaction score
- 0
- Country
Had bathroom refitted about a year ago (not by me, got local plumber in to do job).
Have noticed a few very slight leaks starting to develop around a some of the joints on the pipe work.
Is it worth splitting and attempting to reseal each joint? I’m assume a copper olive has been used in the compression fitting as there is a green build up around the connections.
Is copper the best material to use? Or should I replace with brass or something else?
Also on the threaded connection to the cistern, what are the best washers to use? Fibre or Rubber?
